And here they are...
Nice cars dude :-)
Wish you fun with your s2k which you will surely have ;-)
Greets
Ahmet
Nice cars dude :-)
Greets
Ahmet
UPDATE (at last )
EJ9 Midori:
B20/B18 swap ('99 JDM CRV block/'99 98 spec JDM DC2 head)
98 spec S80 gearbox
Hasport mounts
Hasport axles
Custom intake with velocity stack filter
Meziere electrical waterpump
Tein Flex
Tein EDFC
4x114,3 JDM DC2 conversion
1"5x6,5J ET45 4x114,3 Sprinthart CP-F
Suspension Techniques swaybars, bushings, brackets and endlinks
Most of the parts are still in order.
Before we start installing everything the engine bay will be painted in Midori. As also the doorstrips.
Still thinking what to do with the exterior. Have an original Air Walker bodykit which can be installed, but i'm not sure if this will proceed.
Lot's of more updates will follow quite soon.
JDMP AP1:
Backyard Special seatrails (installed)
OEM hardtop (ready to be installed)
Volk EVO4 (at the painter for a new colour)
Custom J's header with titanium finish
Spoon valvecover
Nice Updates dude
Like the upgrades Ian!
Please post some Pics of the Midori EJ when the parts are installed
Airwaker would be a great decision!
Geändert von JHMEK4 (11.09.2009 um 12:53 Uhr)
The new set up for the Midori EK, not complete but a good start:
Frankenstein engine ('99 JDM CRV - '99 98 spec JDM B18C-R)
98 spec S80 LSD gearbox
Brian Crower Camshafts
Brian Crower valves
Brian Crower valve springs
Brian Crower retainers
Bisimoto header based on enginespecs with 2,5 inch collector
Bisimoto cam gears
2,5 inch APE high flow cat
2,5 inch cat-back
ARP bolts
IM will be portmatched to 68mm
68 mm throttlebody
Custom intake met velocity stack filter
Hasport mounts
Hasport axles
ACT Street disk kit (not 100% sure)
ACT lightweight flywheel
Mishimoto full size radiator with full size scrout
Bekerom Tuning ECU
NGK sparkplugs and sparkplugcabels
Chasebays loom
Gelbattery incl. relocation kit
Oil filter relocation kit
Meziere electronical waterpump
As said this will be the set-up for known. Still figuring some things out.
Goal will be about 260 hp N/A.
Sounds nice dude!
Waiting for Updates ;-)
