Ergebnis 1 bis 9 von 9
Thema: US 2008 Honda Civic SI
    Standard US 2008 Honda Civic SI
    Avatar von TiLLy89
    Herne
    Ähm... etwas dürftig das ganze hier
    ja daten zum auto wären nicht schlecht
    I would like to sell my 2008 honda Civic SI. It is US Specso if you would like to have it, then you would have to pay for the zoll and Germanyspec transferring. It isin Mannheim Germany. I bought it through the US military agreement,whichincluded the shipment to Germany. My spouse and I are expecting a newadditionto the family so I have to sacrifices my car for a bigger one. Ya? Imeanya!!.. I'm the only owner of the car. It has 23,300 miles and I think38,000 somethingkilometers, no problems outside or inside. Single CD player,with auxiliary mp3player inputs. No aftermarket part, it is all factory. Ifollowed all warranty maintainsschedules, with warranty book to show prof. Amy other question pm me.
    hat der jezz deutschen tüv oder nich..alles komisch irgendwie????
    German TÜV Yes or no????
    whats the price for this car???
    Geändert von marcosleandros (22.09.2011 um 16:28 Uhr)
    Cologne
    Du musst wenn du das Auto kaufst nach verzollen und versteuern! Ist einer von der Ami Base die haben nen Abkommen das sie "Ihr" bzw ein Auto mit nach Deutschland nehmen dürfen und dafür kein Zoll und keine Steuern zahlen müssen! Also musst du auch deutsche Papiere +zoll und steuern blechen!
    No it does not have TUV, and yes you would have to pay for all taxes to import the car. You would have to get the TUV yourself. Price for the car is 17,000 Euros Or Best offer.
    Engine Type In-Line 4-Cylinder
    Engine Block/Cylinder Head Aluminum-Alloy
    Displacement (cc) 1998
    Horsepower @ rpm 197 @ 7800
    Torque (lb.-ft. @ rpm) 139 @ 6100
    Redline (rpm) 8000
    Bore and Stroke (mm) 86 x 86
    Compression Ratio 11.0:1
    Valve Train 16-Valve DOHC i-VTEC®
    Stainless Steel Exhaust Manifold Standard
    Multi-Point Fuel Injection Standard
    Drive-by-Wire™ Throttle System Standard
    Front-Wheel Drive Standard
    CARB Emissions Rating LEV-2
    Direct Ignition System with Immobilizer Standard
    100K +/- Miles No Scheduled Tune-Ups[1] Standard
    Immobilizer Theft-Deterrent System Standard
    Transmissions
    Civic Si Sedan
    Close-Ratio 6-Speed Manual Transmission Standard
    Helical Limited-Slip Differential Standard
    Body/Suspension/Chassis
    Civic Si Sedan
    Unit-Body Construction Standard
    MacPherson Strut Front Suspension Standard
    Multi-Link Rear Suspension Standard
    Stabilizer Bar (mm., front/rear) 27.0 (solid) / 17.0
    Power-Assisted Rack-and-Pinion Steering Electric
    Steering Wheel Turns, Lock-to-Lock 2.65
    Steering Ratio 13.62
    Turning Diameter, Curb-to-Curb (ft.) 35.4
    Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in., front/rear) 11.8 / 10.2
    Wheels 17" Alloys
    All-Season Tires P215 / 45 R17 87V
    Michelin® Pilot® Exalto® PE2™ Performance Tires (available) 215 / 45 ZR17 91W
    Compact Spare Tire Standard
    Exterior Measurements
    Civic Si Sedan
    Wheelbase (in.) 106.3
    Length (in.) 176.7
    Height (in.) 56.5
    Width (in.) 69
    Track (in., front/rear) 59.0 / 60.2
    Curb Weight (lbs., MT/AT) 2945 / NA
    Weight Distribution (%, front/rear, MT) 60 / 40
    Weight Distribution (%, front/rear, AT) NA
    Interior Measurements
    Civic Si Sedan
    Headroom (in., front/rear) 38.1 / 36.7
    Legroom (in., front/rear) 42.2 / 34.6
    Shoulder Room (in., front/rear) 53.6 / 52.3
    Hiproom (in., front/rear) 51.9 / 51.0
    Cargo Volume (cu. ft.) 12
    Passenger Volume (cu. ft.) 88.4
    Seating Capacity 5
    EPA Mileage Estimates[2] / Fuel
    Civic Si Sedan
    6-Speed Manual (City/Highway/Combined) 21/29/24
    Crankcase (qt.) 5.8
    Coolant System (qt., MT/AT) 6.7 / NA
    Fuel (gal.) 13.2
    Required Fuel Premium Unleaded
    Safety
    Civic Si Sedan
    3-Point Seat Belts at all Seating Positions Standard
    Front 3-Point Seat Belts with Automatic Tensioning System Standard
    Driver's and Front Passenger's Seat Belt Reminder Standard
    Adjustable Front Seat Belt Anchors Standard
    Dual-Stage, Dual-Threshold Front Airbags (SRS) Standard
    Front Side Airbags with Passenger-Side Occupant Position Detection System (OPDS) Standard
    Side Curtain Airbags Standard
    Driver's and Front Passenger's Active Head Restraints Standard
    Advanced Compatibility EngineeringTM (ACETM) Body Structure Standard
    Anti-Lock Braking System (ABS) Standard
    Electronic Brake Distribution (EBD) Standard
    Vehicle Stability Assist™ (VSA®) with Traction Control Standard
    Tire Pressure Monitoring System (TPMS) Standard
    Daytime Running Lights (DRL) Standard
    Side-Impact Door Beams Standard
    Outboard Lower Anchors and Tethers for Children (LATCH) Standard
    Child-Proof Rear Door Locks Standard
    Emergency Trunk Opener Standard
    Exterior Features
    Civic Si Sedan
    One-Touch Power Moonroof with Tilt Feature Standard
    Integrated Rear-Window Antenna Standard
    Security System with Remote Entry with Trunk Release
    Body-Colored Power Side Mirrors Standard
    Variable Intermittent Windshield Wipers Standard
    Body-Colored Low-Profile Rear Wing Spoiler Standard
    Chrome Exhaust Finisher Standard
    Impact-Absorbing Body-Colored Bumpers Standard
    Multi-Reflector Halogen Headlights Standard
    Tinted Glass Standard
    Body-Colored Door Handles Standard
    Comfort & Convenience
    Civic Si Sedan
    Air Conditioning with Air-Filtration System Standard
    Honda Satellite-Linked Navigation SystemTM with Voice Recognition Available
    Power Windows with Auto-Up/Down Driver's Window Standard
    Power Door Locks with Auto-Lock Feature Standard
    Cruise Control Standard
    Perforated Leather-Wrapped Steering Wheel Standard
    Aluminum Shift Knob with Leather Standard
    Textured Aluminum Pedals Standard
    Steering Wheel-Mounted Controls Cruise/Audio/Navi(available)
    Tilt and Telescopic Steering Column Standard
    Beverage Holders Front and Rear
    Center Console with Sliding Armrest and Storage Compartment Standard
    Front Door-Pocket Storage Bins Standard
    Passenger-Side Seatback Pocket Standard
    Coin Tray Standard
    Satin-Finish Door-Handle Pulls Standard
    Remote Fuel Filler Door Release Standard
    Remote Trunk Release with Lock Standard
    Headlights-On Reminder Standard
    Driver's and Front Passenger's Vanity Mirrors Standard
    Ambient Console Lighting Red
    Map Lights Standard
    Rear-Seat Armrest Standard
    Rear-Seat Heater Ducts Standard
    Floor Mats Standard
    Driver's Footrest Standard
    12-Volt Power Outlet Front and Center Console
    Rear Window Defroster with Timer Standard
    Cargo Area Light Standard
    Seating
    Civic Si Sedan
    Driver's Seat with Manual Height Adjustment Standard
    Reclining Front Seatbacks Standard
    Adjustable Head Restraints Standard
    Fold-Down Rear Seatback 60/40 Split
    Audio Systems
    Civic Si Sedan
    350-Watt AM/FM//CD Premium Audio System with 7 Speakers including Subwoofer Standard
    MP3/Windows Media® Audio (WMA) Playback Capability Standard
    MP3/Auxiliary Input Jack Standard
    XM® Radio[3] Navigation Models
    CD Text Display Capability Standard
    Digital Audio-Card Reader Navigation Models
    Speed-Sensitive Volume Control (SVC) Standard
    Instrumentation
    Civic Si Sedan
    Two-Tier Instrument Panel Standard
    Blue Backlit Gauges Red
    Tachometer with Rev-Limit Indicator
    Digital Odometer and Digital Trip Meters (2) Standard
    Maintenance Minder System Standard
    Tire Pressure Monitoring System (TPMS) Indicator Standard
    Exterior Temperature Indicator Standard
    Fuel and Coolant Temperature Indicators Standard
    Door/Trunk-Open Indicators Standard
    Low-Fuel and Low-Oil Pressure Indicators Standard
    Passenger-Side Side Airbag-Off Indicator Standard
    [1] Does not apply to fluid and filter changes. May vary with driving conditions. See your owner's manual for more details.
    [2] Based on 2008 EPA mileage estimates, reflecting new EPA fuel economy methods beginning with 2008 models. Use for comparison purposes only. Do not compare to models before 2008. Your actual mileage will vary depending on how you drive and maintain your vehicle.
    [3] XM services require a subscription after 90-day trial period. Subscriptions governed by SiriusXM Customer Agreement; see www.siriusxm.com. If you decide to continue your XM service at the end of your complimentary trial, the plan you choose will automatically be renewed and you will be billed at then-current rates until you call XM at 1-800-967-2346 to cancel. Fees and programming subject to change. Available only to those at least 18 years of age in the 48 contiguous United States and D.C. ©2011 Sirius XM Radio Inc. Sirius, XM and all related marks and logos are trademarks of Sirius XM Radio Inc. and its subsidiaries.
    car looks good and is in a good condition..no question about it but 17000€ are about 23000$. and for that money i could get a 2010/11 sedan in US NEW!!.
    2008 civic SI's in US are about 16-17000 $...including shipping tax,TÜV and so on you can get one for 18000€ compleatly done.
    17000 € including german TÜV and tax are realistic but not without anything.
    you will find nobody here who will invest 5-6000€ additionally to your specified price. finally it would be about 22-23000 € for a 2008 civic....no way
    Geändert von marcosleandros (23.09.2011 um 16:48 Uhr)
    Where did you get 16,000 -17,000? The Kelly Blue book price for trade-in is 16,000. That is not the pricefor private sale. The price for private sale for fair –bad condition is 16,000and less, Good condition is 18000+, great condition is 19,000+. But justremember the price for cars in the US depends on many factors, like mileage, a2008 Honda Civic SI with 50,000 miles will be far less expensive than a carwith less mileage than that like 23,500. Also the Coupe is sold for less thanthe Honda Civic Si Sedan. So if you can find a 2008 Honda Civic Si Sedan beingsold for less than 21,000, and have less mileage than 30,000 than have fun….Just remember to do a VIN Number check on the Car. Oh and again the Price is17,000 €, OR BEST OFFER (Oder Preisvorschlag).
